Arkio runs slowly on my device
Last updated 3 days ago
Arkio's performance threshold is determined by the amount of processing power available on your device. If you are running Arkio on a mobile phone or a standalone headset, operations can go wrong, especially when large amounts of geometry are shown in the scene or there is an error or misconfiguration on your device.
Slow performance in Arkio is often caused by viewing too large scenes or an imported 3D model.
The following steps you can follow to troubleshoot and fix performance issues:
Restart your device
Load a new empty Arkio scene
Connect to a different Internet source and try out the app
Clear and re-import the loaded resources on your device Access and clear user files
Uninstall and reinstall Arkio (make a backup of your scenes or upload them to the Arkio Cloud portal as this will remove your existing user files)
Contact us at support@arkio.is if you tried the above and are still experiencing performance issues on your device. It helps us if you can send your device logs so we can assist and figure out what's going wrong. Collect and send Arkio logs
