Paint
Colors and materials can be applied to the entire shape or to individual faces. To paint individual surfaces of shapes, use the toggle on the Wristband to paint single faces.
Lightly touching the controller's trigger will preview the material on the shape, and pressing it will confirm the object to be painted. If you keep holding the trigger, the paint operation will be applied continuously to all objects hit by the laser. A range of free and content-packed materials is available from the library. We love to hear if you are missing materials that you would like to see included.
With the paint drawer open, you can switch between painting normal materials or assigning program areas to Arkio shapes from the right tab. More on this can be read in Program Studies. We also have some special paint materials, such as the map paint and the Passthrough material.
