Access and manage user files
Last updated 2 months ago
Temporary resource files
If you experience problems with your imported/downloaded content, such as files behaving oddly or not loading or showing in your imported files list. You can best unlink your Arkio Cloud and clear your temporary resource files using the “Clear & restart” button in your settings. This will reprocess all source files in your Import folders and redownload any models and images that have been shared with you when you open the scenes again.
It's also possible to manually remove these resource files and the source files from your device by clearing them from the paths listed at the end of this page.
Import source files
Source files placed in the Documents\Arkio\Import folder will be reprocessed when a new file is added. If your import files are causing issues, you can also remove the source file from the import folder, as those files will be reimported every time you clear the resources cache.
Deleting a source file will not delete your imported files from Arkio, as these files will be processed to Arkio resources in the ResourceCache folder. If you wish to delete a resource from Arkio, you must do so manually from the import tab or clear all processed resources from your settings. This will reprocess all source files that you still have in your import folder on the next Arkio restart.
Arkio scenes
Scenes contain your Arkio geometry and the details for placed imported resources, so if you are experiencing issues with loading your scenes in Arkio, it might be necessary to manually access your files on your device. Arkio scenes are saved as .arkio files on your device and can also be managed manually.
Backups from Arkio
Deleting the Arkio app from your Mac, Quest, iOS, and Android devices will erase all your saved scenes and imported data on that device and completely reset Arkio. Before you delete the app, you can start an Arkio meeting on that device and share the Arkio scenes you want to keep to the Arkio Cloud or to another device running Arkio via a meeting
This way, you will have a backup of your files, and you can share your Arkio scenes back to your original devices after a fresh Arkio install.
Device paths
If you want to manually recover files, use the following paths on your device to find the files you want to restore or clean when experiencing issues.
It's safe to remove the contents of the ResourceCache folder, as it will be reloaded on the next run of Arkio (this has the same effect as pressing the clear button in settings). You can also clear the import and export folder if you're having issues with the data on your device. The Usermodels folder has your Arkio's saved scenes from that device.
OneDrive installations
Some users using Microsoft OneDrive can experience issues with Arkio plugin exports ending up in the incorrect Import path for Arkio.
After your Arkio plugin makes an export, a GLTF file should be placed at %userprofile%\Documents\Arkio\Import\Rhino (or other plugins). In some installations, GLTF files are not saved there, but in OneDrive\Documents\Arkio\Import\Rhino
Uninstalling Arkio completely from your PC and reinstalling the latest version from https://www.arkio.is/download/ should fix this issue. If you have issues with invalid import paths. You can also manually copy files to the above document folders to work around this.
Windows file directories
The easiest way to import and export models in and out of Arkio is to use the Windows installer version of Arkio, which includes the latest version of our plugins and can be downloaded for free from our website.
The following file import directories can be used to manually manage and load files to Arkio offline on your local device. Uninstalling Arkio on a PC will keep your saved scenes and imports in your Documents folder. When you reinstall Arkio, these will reopen.
Imports
Main import directory
Images (JPG & PNG)
%userprofile%\Documents\Arkio\Import\Images
3D models (glTF, GLB, OBJ)
%userprofile%\Documents\Arkio\Import\Models
Archicad plugin imports
%userprofile%\Documents\Arkio\Import\Archicad
Revit plugin imports
%userprofile%\Documents\Arkio\Import\Revit
Rhino plugin imports
Sketchup Plugin imports
%userprofile%\Documents\Arkio\Import\SketchUp
Program imports
%userprofile%\Documents\Arkio\Import\Programs
Invalid imports are moved here
%userprofile%\Documents\Arkio\Import\InvalidImport
Exports
Main Export directory
%userprofile%\Documents\Arkio\Export
Photos and AI photos
%userprofile%\Documents\Arkio\Export\Photos
3D models (GLB, OBJ)
%userprofile%\Documents\Arkio\Export\Models
Plugin export folders
%userprofile%\Documents\Arkio\Export\Revit..
Program Exports
Other user data
Temp resource files
%userprofile%\appdata\locallow\Arkio\Arkio\Arkio\ResourceCache
Arkio debug logs
%userprofile%\Documents\Arkiologs
Mac file directories
You can best use the Arkio Cloud to sync your files to Arkio on your Mac. You can also access Arkio imports, exports, and saved files on Mac from your ~/Library folder. This is a hidden system folder that can be accessed by holding the Option key while opening the Go Menu, or by searching for "Arkio" in Finder.
~/Library/Containers/Arkio/Data/Documents/Arkio/Import
Main export directory
~/Library/Containers/Arkio/Data/Documents/Arkio/Export
~/Library/Containers/Arkio/Data/Documents/Arkio/UserModels
Temp resource files
~/Library/Containers/Arkio/Library/ApplicationSupport/is.arkio.arkio/Arkio/
ResourceCache
Arkio debug logs
~/Library/Containers/is.arkio.arkio/Data/Documents/Arkio/ArkioLogs
Quest file directories
You can best use the Arkio Cloud to sync your files to Arkio on mobile devices. If you are using your Quest in Link Mode, you can use the Windows import/export directories listed above.
To access your local user data on your Quest:
  1. Activate Developer mode on your Quest:
    1. Go to dashboard.oculus.com and sign in using your Quest's Meta account
    2. Create a name for your development "organization" - This can be anything
    3. Verify your Meta account - Set up Two Factor Authentication (via phone number)
    4. Activate developer mode from the Meta Quest phone app:  Devices > Headset settings > Developer mode > Turn on
  2. Connect your headset to your PC using a USB-C cable.
  3. On the headset, when prompted, select "Allow" for your PC to access your headset files
Android\data\com.arkio.arkio\files\Arkio\Import
Android\data\com.arkio.arkio\files\Arkio\Export
Android\data\com.arkio.arkio\files\Arkio\UserModels
Android\data\com.arkio.arkio\files\Arkio\ResourceCache
Arkio debug logs
Android\data\is.arkio.arkio\files\Arkio\ArkioLogs
iOS file directories
You can best use the Arkio Cloud to sync your files to Arkio on mobile devices. iOS users can find Arkio user files in the Files App.
Files\Arkio\Import
Files\Arkio\Export
Files\Arkio\UserModels
Temp resource files
Files\Arkio\ResourceCache
Arkio debug logs
Files\Arkio\ArkioLogs
Android file directories
You can best use the Arkio Cloud to sync your files to Arkio on mobile devices. Android user files can be accessed from their file browser by connecting your phone to a PC using a USB cable, giving permission and going to the following folder
Android\data\is.arkio.arkio\files\Arkio\Import
Android\data\is.arkio.arkio\files\Arkio\Export
Android\data\is.arkio.arkio\files\Arkio\UserModels
Temp resource files
Android\data\is.arkio.arkio\files\Arkio\ResourceCache
Arkio debug logs
