Hand tracking
If you are using the Meta Quest 2 or 3, you can try Arkio's experimental hand modeling to work with most of Arkio's tools. You can activate this by enabling hand-tracking in your device's settings.
With hand tracking enabled, you can put down a controller on a fixed surface and look at your hands. You can switch back to the controllers in Arkio anytime by picking them up again and pressing the menu buttons.
If you are experiencing issues with hand tracking, we recommend switching back to controllers and seeing how it performs in other apps. Your environment and lighting conditions affect tracking and gestures.
Navigation
You can grab and scale the world by forming one or two fists just like using the grip buttons on the side of your controller
Activate the laser and tools
An open hand, palm forward, gesture with your fingers spread (like a stop sign) will show the laser for your active tool on that hand. By using a pinch gesture (thumb and index finger touching) the active tool gets started and this allows you to pick up and edit geometry just like using the trigger on your normal controllers.
Show main menu
A pinch gesture with your thumb and middle finger will open the Quick selection menu, automatically switching the tools on hover. Releasing the pinch will select the latest hovered tool on that hand. You can also select tools by touching the buttons with your index finger.
Teleport
You can teleport by rotating your right wrist up and making a pointing gesture. As long as the teleport mode is activated, you can teleport to the model and back to the sky by pinching your index finger and thumb.
Known issues
Meta is actively improving the hand tracking with each system update. Overlapping hands and bad lighting conditions can interfere with the quality of your tracking
Pinch or grip gestures are not always detected
The hands sometimes lose tracking, making the tools and operations in Arkio not work as expected
You can disable hand tracking on your headset if you don’t want Arkio to switch to hands when you put your controllers down
More in User Interface
Desktop & Mobile user interfacePC VR and hybrid modeVR ControllersFile browserStill need help? Ask the team
