Laser & grab interactions
There are two ways to interact with your geometry in Arkio. You can edit or move shapes from a distance in VR and non-VR by selecting and using Arkio’s main tools. If you are using VR controllers or hand tracking, you can also interact with the geometry directly by reaching into the objects or edges directly with the black interaction point on the controller.
Moving shapes by hand
You can always grab shapes by hand, regardless of the current tool you have selected in Arkio. This simplifies modeling and makes it very accessible to move, rotate, and adjust anything within reach. You can scale yourself to a larger scale to pick up and move around anything in your scene more comfortably.
Editing shapes
To edit shapes, you can select the edit tool from the main menu, or simply reach into shapes with your VR controllers and pull the trigger to move or stretch the shapes' faces, edges, and corners.
