Startup or performance issues on Quest
Arkio's performance is determined by the amount of processing power available on your device and may be affected by importing models that are too large for the device, misconfigurations, insufficient memory, and system errors. If you are running Arkio on a mobile phone or a standalone headset like the Meta Quest and are encountering startup or performance issues, you can use the following steps to troubleshoot.
Troubleshooting steps:
Restart your device
Load an empty new Arkio scene from the files menu
Connect to a different internet source (Some network configurations can block Arkio, and connecting to a tethered phone can bypass this)
Clear and re-import your temporary resources on your device Access and clear user files
Clean your Meta device configuration settings, like “spatial services data" and "physical space history" from Settings>Privacy & Safety
Using more than one Meta account on a single headset can cause startup issues. We recommend using only one Meta account when possible and disabling App Sharing
Uninstall and reinstall Arkio (Make a backup of your important scenes to Arkio Cloud, as this will remove your existing files from your device)
If you have tried the steps above and are still experiencing startup or performance issues on your device, please contact us at support@arkio.is. If you send your device logs, we can see what's going wrong on your device and find a solution, which helps us improve Arkio.
More in Troubleshooting
Report issues by sharing logs to ArkioAccess and manage user filesCannot run Arkio simultaneously on multiple QuestsNetwork Issue for meetings and online featuresStill need help? Ask the team
