Beta
Choose your AI model, reasoning, and speed
Last updated About 4 hours ago
Arkio lets you choose the AI model you work with and adjust its reasoning level and speed. These settings help you balance design capability, response time, and AI credit usage.
How to change your settings
  1. Open the AI model selector and choose Astra, Sol, or Luna.
  2. Choose a reasoning level to control how much effort the model spends working through your request.
  3. Choose a speed. Normal uses fewer credits; faster options increase credit usage.
Which model should I use?
Model
Best suited for
Things to consider
Astra
Detailed design tasks, interiors, reference images, and floor plans
The most capable model. Start with Low or Medium reasoning for most design work.
Sol
General design tasks and everyday changes
Uses substantially fewer credits than Astra, but is less capable at detailed interiors.
Luna
Basic massing, navigating, and inspecting a scene
The least capable model. Best for simple, clearly defined tasks.
For example, choose Astra to develop a furnished interior from a floor plan, Sol to make general changes to a design, and Luna to explore simple building volumes or move around a scene.
Choosing a reasoning level
Higher reasoning levels generally consume more AI credits.
With Astra, Low or Medium reasoning is already capable of handling most design tasks. Use High, Extra High, or Max for your most demanding requests, such as interpreting complex references or coordinating many design constraints.
Start with a lower reasoning level and increase it when the task needs more careful problem-solving.
Choosing a speed
Speed
Approximate credit usage
When to use it
Normal
Standard usage
Everyday work when conserving credits matters
Fast
Around 2–3× Normal
When you want results sooner
Ultrafast — Astra only
Around 6× Normal, at roughly 8× the speed
Demanding work where turnaround time is especially important
These are approximate comparisons; actual usage and completion time depend on the task.
Speed and reasoning serve different purposes: reasoning controls the effort spent on your request; speed controls how quickly that work is processed. Choosing Fast or Ultrafast does not replace choosing a more capable model or an appropriate reasoning level.
A good starting point
Use Astra with Low or Medium reasoning at Normal speed for design work. Try Sol for routine tasks to conserve credits, and Luna for basic massing or scene navigation.
