Create AI renders and videos in Arkio Web
Last updated 8 days ago
Use AI renders to explore the appearance of your design and create short videos to present it. Start from the chat or the Render window above the scene, then find completed results in the Media library.
Sign in with available AI credits and open a scene you can work in. Check the model and choose a useful viewpoint before requesting a render. Generated images and videos are separate from your editable 3D geometry.
Create a render
Position your view in the scene, or prepare named viewpoints in Views.
Select the camera button in the chat message box, labeled Render or video of the scene.
Choose Render and select Current view, Saved views, or Let the agent choose. Saved views uses the saved viewpoints in the scene; check the request summary before sending. When the agent chooses, you can set the number of renders.
Choose a style: Photoreal, Pencil sketch, Markers, Scale model, or Your own. For your own style, describe the look in the message.
Add instructions about materials, lighting, atmosphere, or details to preserve, then send the message.
Choosing the render options prepares a request; generation starts when you send it. You can also ask for a render directly in a normal chat message.
Render the current view as a warm evening interior with oak cabinetry and soft lighting. Preserve the layout, window positions, and furniture arrangement.
Live preview and rendering from the scene
Open Render above the scene to frame a view, explore it with Live preview, or capture it for a finished render or video. You can use Render view with Live preview on or off.
Explore with Live preview
With Live preview off, the window shows the current scene view without using AI credits.
Select Live preview to generate rough AI previews as you explore. Allow the view to settle while the preview updates; generation takes time, so the image may lag behind navigation or model changes.
Select Stop when you have finished. You can keep the window floating over the scene or dock it below the player.
Turn a view into a render or video
Frame the view you want in the Render window and select Render view.
A snapshot of the current model view is added to your chat, with Captured snapshots selected as the source. This captures the model view rather than the AI preview image. It does not start generation or use AI credits.
For more views, move to another viewpoint and select Render view again.
In the chat, choose Render or Video, select a style, add any instructions, and send when ready.
A render request creates a separate image for each captured snapshot. For a video, drag the snapshots into the order you want; Arkio renders them first, then makes the video. The snapshots preserve the views you captured, even if you move the camera afterward.
Live preview uses AI credits while generating updates. Capturing views is free; sending a render or video request uses credits separately. Requests already in progress can still finish and add usage after you stop.
Explore image ideas before modeling
Choose Ideas in the chat's camera controls to compare visual directions before developing them in 3D. Describe the alternatives you want to explore. These images use AI credits without changing your model, helping you choose a direction before spending credits on detailed modeling.
Open the completed image from the chat to inspect it. Compare it with the model: AI images can interpret or add details that are not present in the geometry. Describe the specific image change you want in a follow-up request.
Develop your chosen idea in 3D
Use Build in 3D to ask the agent to develop a selected image in your model. You can also describe which features to combine from different images. Image details and materials are not automatically part of the 3D model; developing them uses additional AI credits. Review the result and ask for refinements where needed.
You can see this in action in this video:
Create a video
Select the chat's camera button and choose Video.
Choose a source. Use Renders in this chat for completed images, Captured snapshots for views you have captured with Render view, or choose the current view, saved views, or views selected by the agent.
When using existing renders, select the images in the order you want the camera to travel. With one image, describe the camera movement; with two, the video starts from the first and ends at the second.
Choose the video length from the available options. Add instructions about the camera movement and pace, then send the request.
Open the completed video in the chat to review it.
Create a 10-second video from these two renders, moving slowly from the entrance toward the courtyard.
Videos made from existing renders use their appearance. To change that appearance, refine the renders first. A video requested from scene views may generate source renders before making the video, so allow for both stages in your credit budget.
Find, download, and share your media
Open a completed render or video in your project chat and select Download to save it. To browse results across your chats, open Media in the left sidebar.
Use the type filters and sorting controls to find a result. Select a tile to open it.
Use the item's menu to Download, or choose Open chat to return to its source conversation.
In a shared scene, use Share to group where available. Review the prepared message in Group chat and send it when ready.
Media from archived chats is hidden from the library. Restore the chat through Archived → Restore to library to show those results again.
Credits and troubleshooting
Typical credit estimates:
Live preview: Around 10 credits per minute.
AI render: Around 5–15 credits per image.
AI video: Around 100 credits for a 10-second video.
Actual usage varies. Videos created from scene views or captured snapshots also require source renders, which add to the total.
Before generating a set of images or videos, consider setting a spending limit for the chat. It pauses new paid requests once reported usage reaches the allowance. Generation already in progress can finish and add charges; the limit does not guarantee a maximum final cost.
See AI models, settings, and credit usage for planning estimates, and AI credits and your work for balances and purchases. Additional attempts and separate agent processing can add to the total.
If Saved views is unavailable, save a viewpoint first. If Renders in this chat is unavailable, generate an image in that conversation first.
If a result or preview fails to load, use Retry where shown and check the original chat before sending a duplicate generation request.
If Live preview reports that another tab is using the live view, stop it there before starting it in this tab.
